Dodge Neon Idle Squealing
STLTHRIOT
  • 31 POSTS
This question is for a friend.
She has a Dodge Neon, not for sure of the year... between '97 and '02. Whenever she idles or sometimes when the car just starts there will be a loud squealing/screeching sound coming from somewhere under the hood.
It mostly happens as she is coming to a stop at a stop sign or light and then sometimes while it is idling there but no sounds at higher speeds above 15mph I think.
She says she's had the belts changed so not sure what else to suggest.
Thanks.
-Chad
Dec 19, 2006 at 5:52 AM
BACKYARDMECHANIC
  • 337 POSTS
Sounds like the belt tensioner is bad .This will cause the belt to slip. Hope this helps
Dec 19, 2006 at 9:14 AM
STLTHRIOT
  • 31 POSTS
thanks! I'll pass the word on to her :)
she mainly just finds it is embarrassing when everyone looks at her when it does it ;)
Dec 19, 2006 at 10:31 AM
Suggested Repair
Inspect and replace the belt tensioner if it is worn, since a bad tensioner can let the belt slip and squeal even after the belts have been replaced.
Conversation Summary
A Dodge Neon from roughly 1997–2002 squeals or screeches under the hood at idle and when coming to a stop, but not above about 15 mph. The belts were already replaced. The expert said a bad belt tensioner is likely allowing the belt to slip.
