2000 Dodge Neon Low Idle
NIRAD33
What is the best way to install plugs and wires in my 2000 dodge neon. It has 84,000 miles on it and has been idling at a very low rpm (800and lower). I was told by one of the mechanics at a local shop this may help adjust the idle.
Apr 22, 2006 at 4:34 AM
VANDRAGON
  • 298 POSTS
i would replace the pcv valve first. it only cost a few bucks. if it is clogged the motor can't get the proper air flow and will idle slower. also check your air filter.
Apr 23, 2006 at 1:50 AM
MARINEMAN9123
  • 7 POSTS
replace the plugs with cheapo champion plugs... believe it or not the neons run best on those.
we tried putting bosch platinums in our neon and it didn't like that too much we switched to champions and it idled like a dream
Jan 11, 2007 at 3:58 PM
Suggested Repair
Replace the PCV valve first and check the air filter, since a clogged PCV can restrict airflow and cause a low idle. If plugs are replaced, Champion plugs were reported to idle better than Bosch platinum plugs on a Neon.
Conversation Summary
The owner of a 2000 Dodge Neon with about 84,000 miles asked how to install plugs and wires, hoping it would correct a very low idle of 800 rpm or below. An expert recommended replacing the inexpensive PCV valve first and checking the air filter. Another reply said Champion plugs idled better than Bosch platinum plugs on a Neon.
