Neon starter
RIDEOFLIFE
I have a 2002 Neon, with 67,000 miles and recently it wont start. when you turn the key it does nothing. all the lights work so, i dont think its the battery. any suggestions?
Sep 20, 2007 at 1:53 PM
BMRFIXIT
  • 19,053 POSTS
1st thing come to mind is the starter
Sep 20, 2007 at 1:55 PM
RIDEOFLIFE
i tested the battery, starter, and the starter relay and all are good, but i still cant get any response from the car.
Sep 24, 2007 at 5:41 PM
  • 55,732 POSTS
if it is automatic try moving the gear shift to neutal and crank it, if it starts the switch is bad and needs replacment, if it is stick shift try bypassing the clutch switch and try it, if it starts the swiych is bad and needs replacment, please let me know
Sep 25, 2007 at 6:40 AM
RIDEOFLIFE
its an automatic, and i tried starting in park and neutral, (per your suggestion) and i got no response on either one
Sep 25, 2007 at 6:54 AM
  • 55,732 POSTS
try taking a test light and test the small trigger wire to the starter, crank to see if it lights up.please get back to me.
Sep 25, 2007 at 7:07 AM
