ignition problem, NO SPARK!! help!!
KILLAKDC5
i have a DOHC 97 neon, and it was backfiring when i accelerate and bogging bad..so i changed the plugs...seemed like it got better but now it just wont start.....there is no spark on the wires at all.....autozone said that the distributor is good at 12.5 volts, but it could still be bad right?
any help would be appreciated....thanks
corey
Nov 11, 2007 at 10:33 AM
  • 75,988 POSTS
Could be the magnetic pick-up coil in the distributor or the igniton control module or the computer.
Nov 11, 2007 at 10:37 AM
KILLAKDC5
what is the ignition control module? and how do i know if the ecu is bad?
Nov 11, 2007 at 11:08 AM
  • 75,988 POSTS
The ICM is the one that tells the coil to fire the sparkplugs-If the ECU don't get an ignition signal whether it would be a CPS or distributor pick-up it would not tell the ICM to fire the coil.
Could be the computer if wires checks out for shorts and open and brand new parts on the ignition system, and wired correctly it s gonna come down to the ECU.
Try scanning for code/s
Nov 11, 2007 at 12:21 PM
KILLAKDC5
no codes.......put a new s/down relay in still nothing.....
Nov 11, 2007 at 1:36 PM
  • 75,988 POSTS
Pull the coil wire from the distributor and ground it while cranking it over-do you have spark-if you have spark and nothing at the sparkplugs-replace your rotor and distributor cap it has to make it out of there to get to the plugs.
If nothing at the coil wire-and battery voltage is reaching the coil-recheck the pick-up coil in the distributor, ignition control module-this checks out and the wiring from and to the computer and distributor-you're look at the computer.
Nov 11, 2007 at 6:33 PM
