2000 Plymouth Neon Lights Flicker and Stall
HELLOHEATHER
Hello. I have a Plymoth Neon 2000 model with 108,000 miles. The problem I am having with my car is that not one single mechanic I have taken my car to can figure out exactly what is wrong. The problems are varied so bare with me. First of all the headlights and interior lights dim and flicker. I notice a lot more problems when the headlights are on but they don't have to be for me to see a nice light show inside my car. By this I mean that all the lights on my console flash (seatbelt, airbag, brake, check engine,ect.), the gas gauge swings all around, speedometer swings, temp gauge drops to cold, the left turn signal is lighted up without being on (if I turn on the right turn signal the car stalls and imediately goes dead)(also the headlights are dim without even being turned on) and while this is happening if I turn the headlights on it will also stall. When trying to test other things on the diagnostic machine I tried to press the accelerator and it couldn't stay steady enough to test anything. When we checked the spark plugs there was oil pooled in 2 of the sockets so we changed out the wires and plugs. It hasn't been a problem since. The alternater tested ok but when we pulled it out it was faulty so it was replaced and within a week it began to go bad again. We changed the computer. We also got a new battery. With all these things being changed without anything being fixed the cost is adding up. I have had the grounding wires for the battery checked and everyone says they are fine... but I was wondering if it is possible for one of the wires to be shorted out or something... Any ideas would be welcome. I am a woman so if some of these explainations are vauge I appologize. Thankyou.
Jul 30, 2006 at 4:05 PM
VANDRAGON
  • 298 POSTS
sounds like a short or bad ground. as for the ghosts, look in the trunk, sence the car was made in mexico.
my bad, just a joke!
Aug 3, 2006 at 12:12 PM
PUANA
I agree with vandragon. Since you said you have had the ground checked I would say its a short. The problem is you don't know where the short is. You'll need some one to go over your entire wiring harness which means a lot of time consuming labor. It will get expensive.
Aug 4, 2006 at 7:33 PM
BUBBA_KOSKI
  • 129 POSTS
first things first when you installed the alternator did you install it on a fully charged or new battery? if not that can cause you alternator to burn out within a week or two. Second, the wiring harness can cause that problem, but not likly (im not saying it wont cause it) but check and replace all circuit boards as needed, my buddy had the same problem, but not as severe, i told to check and change the boards as needed, all went bad all change and all problems fixed.
Sep 28, 2006 at 4:22 AM
Suggested Repair
Confirm the battery is fully charged before installing an alternator, since a weak battery can quickly damage a new one. Recheck battery and engine grounds, inspect the wiring harness for shorts, and test or replace faulty instrument-cluster circuit boards.
Conversation Summary
The owner of a 2000 Plymouth Neon reports flickering lights, erratic gauges, and stalling when the headlights or turn signals are used. Spark plugs, wires, the alternator, computer, and battery were replaced without a lasting fix. Replies suggest a short or bad ground, a full wiring-harness inspection, confirming the battery was fully charged when the alternator was installed, and checking instrument-cluster circuit boards.
