1996 Dodge Neon Spark Plug Backs Out
BAGHDEEZY392
96 dodge neon 2.0 SOHC 123k , about a week ago out of nowhere my spark plug came out. thought it might have not been tightened on last tune up.yesterday white smoke came out exust ,and under the hood...the spark plug was out again.along with the heat sheild..what would cause this and what do I need to do to fix this..please help
Apr 5, 2006 at 9:23 PM
PEPPERMRJ
  • 1,158 POSTS
I would think that the threads were stripped. Aluminum heads can be problems if the plugs are not replaced on a stone cold engine.
They are expensive but do not require cylinder head removal with careful installation. Several other companies offer similar products. Do a Google or check with your local auto parts house.
Good luck and let us know. :)
Apr 9, 2006 at 1:29 AM
Suggested Repair
The spark plug threads in the aluminum head are likely stripped, which can happen if plugs are installed or removed when the engine is not stone cold. Have a spark plug thread repair insert installed carefully without removing the cylinder head, and check local auto parts stores for suitable kits.
Conversation Summary
The owner of a 1996 Dodge Neon 2.0 SOHC said a spark plug came out, then white smoke appeared from the exhaust and under the hood and the plug and heat shield came out again. The expert said the plug threads were likely stripped and recommended a thread repair insert that can be installed carefully without removing the cylinder head.
