I have a 2004 dodge neon the shuts off when you make a hard left hand turn, you lose all power. iI been told it was the abs wire hanging that was hitting the tire and shorting out a 20 amp fuse. Had that fix but it is still doing it. Took it to auto zone to check the codes but was told machine only checks for bad codes want pick up electrical problems. When it goes out you can not crank or steer it, once you replace the fuse it works find until you make a hard left turn. I don't have a manuel to tell me what the fuse is for, just keep being told it is electrical. Any help you could give me, tired of taking it to people and they guess at it. I just want someone to fix it. Any thoughts on locating the problem?
Nov 23, 2008 at 1:34 AM
