Vacuum hose diagrams?
NCWEISI
  • 2003 DODGE NEON
  • 4 CYL
  • FWD
  • 130,000 MILES
What is the hard plastic hose connecting between the air filter and the engine? Mine has a hole in it and I think it is causing my engine to run rough.
Saturday, November 7th, 2009 AT 4:20 AM
BMRFIXIT
  • 19,053 POSTS
https://www.2carpros.com/forum/automotive_pictures/99387_Graphic1_593.jpg
You should be able to replace it or repair it with any hose that fit
available at any part store
Saturday, November 7th, 2009 AT 5:13 AM
JEFF BERGERON
  • 5 POSTS
My 2003 Dodge Neon showed code PO456 the vapor canister was replaced and code went away, and it passed emissions, two weeks have passed, and check engine light is back again showing same code (detected small leak) also P1684 battery disconnected which it is not only five months old and voltage is 12.74 possible bad vacuum hose leak maybe?
Monday, March 27th, 2023 AT 12:44 PM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 54,291 POSTS
Please post your new question here, you must be logged in.
Cheers, Ken
Monday, March 27th, 2023 AT 1:37 PM
