2003 Dodge Neon Only getting 16mpg
THERESA17
Engine Performance problem
2003 Dodge Neon 4 cyl Automatic 136000 miles
Hi there,
I have a 2003 Dodge Neon SXT and since October I have only been getting at the most 200 miles to a tank. With my math thats around 16MPG. I am doing city driving but it has never been that bad.
I have checked my tire pressure, changed my air filter, got a tune-up with new plugs and wires, just changed my water pump and timing belt and did the tranny filter and fluids as well. Nothing has helped (I'm not sure if it would even just wanted to give the basic up-keep)
My mechanic sid that no error codes are showing. It also does not seem like I have a leak.
I can't think of what else it would be that is causing such a drastic drop in my mpg.
Any help would be appreciated.
Thank you!
May 28, 2009 at 8:24 AM
CARADIODOC
  • 34,413 POSTS
The MAP and O2 sensors have the biggest effect on fuel mileage. As long as the voltage readings are within specified limits, no fault code will be set in memory but the engine computer will respond accordingly to the incorrect values. A vacuum leak in the hose to the MAP sensor will mimic acceleration, and the computer will command a richer mixture from the injectors. An exhaust system leak ahead of the oxygen sensor will draw in air between the exhaust pulses from the engine. The sensor sees the unburned oxygen so it tries to increase fuel delivery. There will be too much raw fuel going out the exhaust, but the sensor doesn't measure unburned fuel, it still sees the unburned oxygen, so it keeps trying to enrich the mixture. You should see black smoke and smell the unburned fuel at the tail pipe, but the computer still thinks it's running too lean.
The torque converter should lock up above 45 mph strictly as a fuel savings feature. If you have a tachometer on the dash, you can watch the operation; if not, you'll have to listen carefully to the engine. While traveling at highway speed, and the engine is warmed up, hold the gas pedal steady, then very lightly tap the brake pedal for just a fraction of a second. Engine speed should increase about 200 rpm for about two seconds, then go back down as the converter locks up again. The torque converter unlocks when you tap the brake pedal or take your foot off the gas pedal in preparation for an expected stop. If there's no indication the torque converter is locking up properly, first try pulling the brake pedal up a little with your foot while driving on the highway. If it locks up now, suspect a brake light switch out-of-adjustment.
Another thing I've been running into more and more lately is a locked up brake caliper. Stop on a small incline, then put the car in neutral and take your foot off the brake pedal. The car should creep downhill on its own. You should also be able to push the car by hand on a flat surface. If not, feel around the center of the two front wheels. If one feels hot, that brake has been dragging. The common cause is the rubber hose is constricted by rust buildup inside the metal bracket that's crimped around the center of the hose. Opening that crimp just a little with a channel-lock pliers will solve the problem. After working on cars for 26 years, and never seeing this problem even once, I ran into it twice in two weeks. One was a Caravan I had parked for the winter, and the next one was on a student's Neon. When this problem occurs, you can find it very easily if you jack the front end off the ground and put the transmission in neutral. You will be able to rotate one tire very easily by hand. The other one will not turn at all unless you open the brake caliper's bleeder screw to release the pressure.
caradiodoc
Jun 3, 2009 at 9:04 AM
