1997 Dodge Neon
ESOCCER56
Engine Cooling problem
1997 Dodge Neon 4 cyl Manual
Hey I have a 1997 dodge neon I just changed the water pump, timing belt, and the thermostat because it was overheating, but now I'm still haveing the same problem, when it overheats and I hit the gas the temperature goes down then when I start driving it goes up again. Do u know what the problem is because its driving me crazy?
Nov 10, 2009 at 12:31 AM
CHEECH6922
  • 7 POSTS
check your thermostat and your radiator cap. also check the relay for the cooling fans. Mine went out and i had to change everything before i realized that the fans weren't turning on correctly. It is located under the battery and its bolted to your car frame.
Jan 19, 2010 at 9:30 AM
