hello and thank you in advance for looking through this. i have a 2000 neon i just bought for my son and i replace the timing belt, water pump, alt.belt, powesteering belt, upper and lower engine mount, trans fluid and filter and did a full tune-up. my problem is that the car runs really good, engine sound really great and shift fine. when i come to a stop, the idle goes down a little and the whole car vibrates, when that happens i put in neutral and put it back in drive. the vibration stop. i cleaned the throttle body really good and clean the iac valve but no luck. it's not throwing any code. i know i did the timing right. i check for a vaccum leak only found one but that did no solve the problem. i do a lot of side job on cars and this really is giving me a head ache. im thinking of replacing the iac valve but don't know if that will help. any reply or help please.
Aug 27, 2009 at 2:28 PM
