2002 Dodge Neon wont start
DALLAS523
  • 2002 DODGE NEON
Engine Mechanical problem
2002 Dodge Neon Two Wheel Drive Automatic 144000 miles
my car started earlier today but when I got in it later it would not start I had some one give me a jump but that did not work I have power in the car like radio lights what is the problem
Sunday, December 20th, 2009 AT 3:27 PM
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard.
Thursday, September 7th, 2017 AT 4:38 PM
