2002 Dodge Neon Spontaneous Oil Leak
92,125 MILES • 4 CYL • 2WD • AUTOMATIC
1WISKEY
While driving at highway speed,my wifes Neon had a spontaneous transmission oil leak. It "bumped"
twice and the car was curbed immediately. She had no idea that it was a tranny leak until she got out and saw the streak of oil on the pavement. No dash alarms.The car was in the correct gear. What caused this ? Is there a seal that can be a simple fix that may have let go? Am I going to have to get a new tranny for the car?That's 3 questions..sorry! I do not use my credit card on line for anything but will send a donation if you send me the mailing info. In the economic times I wish I could send more.Thanks
Mar 14, 2009 at 3:43 AM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:e8e49d59a2="1Wiskey"]Transmission problem
2002 Dodge Neon 4 cyl Two Wheel Drive Automatic 92125 miles
twice and the car was curbed immediately. She had no idea that it was a tranny leak until she got out and saw the streak of oil on the pavement. No dash alarms.The car was in the correct gear. What caused this ? Is there a seal that can be a simple fix that may have let go? Am I going to have to get a new tranny for the car?That's 3 questions..sorry! I do not use my credit card on line for anything but will send a donation if you send me the mailing info. In the economic times I wish I could send more.Thanks[/quote:e8e49d59a2]
First thing would is to crawl under the vehicle and take a look. It can be as simple as a tranny line has failed. There are 2 line that go from the tranny to the radiator they are cooling lines check them out. next could be a seal at either CV AXle going into the tranny, then there is the front pump seal which would be the most expensive fix because the tranny needs to come out.
Mar 14, 2009 at 3:58 AM
