2002 Dodge Neon
TINK2683
  • 2002 DODGE NEON
2002 Dodge Neon Automatic
I have a 2002 Dodge Neon every time I push on the gas to accelerate my car sputter or hesitates. Then when I push on the gas to make it go it speeds up then go back to normal. What could be the problem?
Thank you
Tuesday, March 23rd, 2010 AT 11:21 PM
Lack of acceleration, chugging, hesitating, bogging etc. Could be caused by one of the following below.
Inspect and test all the following listed below and get back with some results
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Tuesday, March 23rd, 2010 AT 11:28 PM
