2001 Dodge Neon OBD II codes P0601 and P0107
2001 DODGE NEON
185,000 MILES • 4 CYL • 2WD • AUTOMATIC
DRTONER
Engine light came on and got codes above. Codes will not clear. Based on what I read it sounds like one could be caused by the other. Believe it has something to do with PCM. Guys at parts stores tell me they never or rarely go bad and to look for wiring or grounding issue. Part is expensive (275.00) and non-returnable. What do you guys think and can you tell me where this thing is? I cant find it.
Nov 8, 2010 at 3:25 AM
  • 110,240 POSTS
The PO601 is most likely the issue here. In most cases this means the PCM has gone bad. This is usually due to a short-circuit inside the PCM, or if you disconnected the wires/connector from the PCM while the battery was still connected. Chances are the PO107 is the result of the PCM. Basically, the code is set by a serial communication failure inside the computer at least 6 times. Chrysler products are known to have this issue; however, it happens to all. You may get lucky and a dealer may be able to get a dealer to reflash it and make it work. But again, usually replacement is the final repair.
Nov 19, 2010 at 6:58 PM
HIGGINSGP
I think mines being caused by bad engin mounts. The engine is moving and sometimes causes hard shift downshift at low speeds. I'm not safest but I'm one of the brokest haha rez runner
Mar 28, 2016 at 10:55 AM
