2003 Dodge Neon Mi tested my car and i got po132, po440, po
2003 DODGE NEON
112,520 MILES • 4 CYL • 2WD • AUTOMATIC
DORJAN
My car is 2003 dodge neon SXT 2.0. I start my car and press the gas pedal my car starts to shakes, and sometimes it the car shakes and press the gas pedal doesn't go and then its turns off. And then I wait like 30s to a minute and start the car and the car runs good. I went to Autozone and tested and i got po132, po440, and po441. WHAT DO YOU THINK AND RECOMMEND?
Nov 23, 2009 at 7:44 AM
  • 31,937 POSTS
Hi there, the first code is an O2 sensor fault, the others are EVAP system faults, i would first be checking for vacuum leaks, and do a general tune, the O2 fault may not be a faulty sensor, but a bad reading due to a tune fault, also check for any up stream exhaust leaks, and have the EVAP system fully checked as well. start here.
Mark(mhpautos)
Nov 23, 2009 at 7:50 AM
