2000 Dodge Neon Won't Start P0171
JUNE BUG
2000 Neon 80, won't start has code of Po171system too lean what does this mean
Oct 1, 2007 at 10:41 AM
BMRFIXIT
  • 19,053 POSTS
[quote:5548dcaca4="June Bug"]2000 Neon 80, won't start has code of Po171system too lean what does this mean[/quote:5548dcaca4]
P0171 System Lean
Vacuum leak is the most common for this code
As far car with no start check fuel pressure
Check for spark
check timing belt
And let us know we can help
ps engine size will help
Good luck
Oct 1, 2007 at 11:39 AM
Suggested Repair
For P0171 (system too lean), inspect for a vacuum leak first. For the no-start, check fuel pressure, spark, and the timing belt. Engine size would help further diagnosis.
Conversation Summary
A 2000 Dodge Neon will not start and has code P0171, system too lean. The expert said a vacuum leak is the most common cause of that code and advised checking fuel pressure, spark, and the timing belt, noting that engine size would help.
