2000 Neon 80, won't start has code of Po171system too lean what does this mean
Oct 1, 2007 at 10:41 AM
For P0171 (system too lean), inspect for a vacuum leak first. For the no-start, check fuel pressure, spark, and the timing belt. Engine size would help further diagnosis.
A 2000 Dodge Neon will not start and has code P0171, system too lean. The expert said a vacuum leak is the most common cause of that code and advised checking fuel pressure, spark, and the timing belt, noting that engine size would help.
