2000 Dodge Neon dodge neon problem?? check engine light?
MARKWITHAK
Engine Mechanical problem
2000 Dodge Neon 4 cyl Front Wheel Drive Automatic 174xxx miles
I have a 2000 dodge neon, it idles fast when you start it, then it surges, it is getting very bad gas mileage now also. I have replaced the throttle position sensor, the idol air sensor/valve, map sensor, cam position sensor, and intake duct. The car will do 50 mph down the highway without your foot on the gas pedal. when you disconnect the map sensor it will idol alright, still rough but not high or surging, thought the 1st map sensor was bad but I have tried 2 different brand new ones. I cant seem to figure it out. The computer at advanced auto parts pulls a "manufacture code"
Feb 1, 2010 at 12:18 AM
CARADIODOC
  • 34,416 POSTS
Most of the parts you replaced won't cause the symptoms you listed. This sounds typical of a vacuum leak or an exhaust leak.
A leaking vacuum hose or intake manifold gasket will allow extra air in. The oxygen sensor in the exhaust system will see that air and tell the engine computer to hold the injectors open longer to match that air with extra fuel. Engine speed will go up, but the oxygen sensor will still be seeing the extra unburned oxygen.
O2 sensors do not measure exta fuel, only unburned oxygen. The computer will kep dumping in extra fuel, but it will never be enough. When the engine is still cold, use a squirt bottle to spray water on the intake gasket and vacuum hoses while the engine is running. When you find the leak, the water will get sucked in harmlessly and the engine will slow down.
An exhaust leak will cause a similar problem. Between each pulse of exhaust flow, momentum causes a pulse of vacuum. If the leak is before the O2 sensor, air can be drawn in through the leak. The air again will be detected by the O2 sensor, and the computer will command an increase in fuel. Usually this just kills fuel mileage and doesn't affect idle speed.
The MAP sensor measures load on the engine. This sensor has the greatest affect on fuel delivery, but they usually fail over a period of minutes or hours, not days or weeks. Upon total failure, the engine computer will memorize a diagnostic fault code, turn on the Check Engine light, and it will disregard the sensor's reading. The computer will run the engine as well as possible with the missing sensor. Neither performance nor fuel mileage will be good, but you might be able to drive to the repair shop. Often the engine will stall unless you are physically moving the gas pedal up or down. It should not cause a high idle such as you described.
The throttle position sensor is only used to verify the MAP sensor's call for more fuel due to increased load on the engine. The computer also watches its readings to determine direction and rate of movement of the gas pedal. The will be some surging, or "hunting" of idle speed, but a defective TPS won't cause excessively high idle.
caradiodoc
Feb 9, 2010 at 10:22 AM
