2000 Dodge Neon Brake light and check engine light
LNBVT
  • 2000 DODGE NEON
Brakes problem
2000 Dodge Neon 4 cyl Automatic 91000 miles
My check engine light comes on frequently, though every time I have had a diagnostic check I end up paying $90 to be told I have a faulty gas cap. So, I stopped having it checked. I goes off within a few days of getting gas, or sometimes regardless. It went on a few days ago, and then today the brake light went on as well. That has never happened. It felt a bit like the brake pedal was less resistant to my pushing on it. But then that went away, the light went off, less than five minutes later it went back on, but the brakes felt normal, except maybe once every five times I braked. Possibly something serious? Very recently had an oil change and engine mount replacement.
Tuesday, May 27th, 2008 AT 8:48 PM
BMRFIXIT
  • 19,053 POSTS
You can get the codes by cycling the key on off three times
also check brake fluid level and if low
check brakes
you may be due for a brake job
check around more and more shops offering the service for free
Tuesday, May 27th, 2008 AT 9:25 PM
Related Check Engine Light Content
