1999 Dodge Neon camshaft position Sensor
HANKNATOLI
  • 1999 DODGE NEON
  • 4 CYL
  • FWD
  • 83,000 MILES
Is there any way to check the camshaft position senssor?
Tuesday, August 4th, 2009 AT 1:00 AM
BMRFIXIT
  • 19,053 POSTS
What do you have for codes
check if you have SYNC between cam and crank
if no start check timing
Sunday, August 9th, 2009 AT 7:17 AM
HANKNATOLI
No codes, car will start and drive for a little while, then stall, then no start. How do I check SYNC
Sunday, August 9th, 2009 AT 9:10 AM
BMRFIXIT
  • 19,053 POSTS
Very common for it to start when cool and stalls when heated up
after its stalls check if you have crank signal
using a scanner check for RPM reading when cranking
if you have rpm reading then its not the crank sensor if no reading sensor NO good
also
After it stalls
key on do you have check engine light (you should )
crank engine does the light go out as you cranking
if not suspect bad crank sensor
Sunday, August 9th, 2009 AT 6:55 PM
