1999 Dodge Neon bad a/c
1999 DODGE NEON
116,834 MILES • 4 CYL • FWD • AUTOMATIC
SHANO76
checked all fuses and relays compresser not kicking in. put 12 volts to compressor it kicks in. where may the problem lie
Mar 19, 2008 at 4:42 PM
MEANOLDCRAB
did you checked the relay on firewall where the wires go from the compresser up to a little connector on firewall. i had to replace that relay on a neon i use to have which had same problem you say you are having just track wire from compresser up to a small black connector on fire wall where the compresser wires go into and its also a relay swithch to find out if thats the problem unplug compresser from wird connector use a jumper wire and jump between the connect sides if a/c compresser works replace that connector. from any auto store or most liklly a NAPA store.Good luck.
Mar 19, 2008 at 5:08 PM
