1998 Dodge Neon malfunction in elect circuit in cylinder#1
1998 DODGE NEON
120,000 MILES • 4 CYL • 2WD • AUTOMATIC
DRELIX
  • 5 POSTS
i have a rough idle and even worse when the engine has a load on it(in gear) here are the fault codes:P0201,P0202,P0300,P0302. i have changed plugs,wires,air filter,ASD relay,cleaned the TB.i can disconnect the injector connectors on #1 and #2 and have very little change in the way the engine runs.i tested the injectors and they all read around 12 to 13 ohm.and can i use a jumper wire from injector # 3 to # 2 and #4 to #1 just to see if it is the connectors?or not?
Jan 4, 2008 at 3:02 PM
DRELIX
  • 5 POSTS
make a donation and get no answer.
thanks alot
Jan 5, 2008 at 11:36 AM
  • 55,432 POSTS
I would not do that, I would check for a shorted fuel injector. this guide can help
https://www.2carpros.com/articles/how-to-test-a-fuel-injector
Dec 18, 2024 at 5:10 AM
