But you know it not fine
you need to hook a fuel pressure gauge on it and take it for a ride while watching the fuel pressure when it does it
also check if you have any codes stored in the TCM and not the PCM
some time you need to step away take a brake and start from the basic
disconnect the O2 sensor and drive it and check if any better replace O2 sensor
Wednesday, April 30th, 2008 AT 6:38 AM
