1998 Dodge Neon brakes sticking
105,000 MILES • 4 CYL • FWD • AUTOMATIC
CAYRER
My brakes are randomly sticking, i believe in the front drivers side. I can smell pad burning.only happens about once or twice a month.I susoected the driver front caliper was seizing so i replaced it. problem still there. I also replace the brake hose. When it sticks the pedal gets hard and it pulls to the right if i apply the brakes. Should i replace the other caliper or suspect the master cylinder or proportioning valve.
Nov 12, 2008 at 4:46 AM
MASTERTECHTIM
  • 4,750 POSTS
make sure the brake pedal is releasing fully. i have found several with brake light switches that hold the brake pedal on just a little bit causing just enough pressure to apply brakes.
Mar 11, 2021 at 6:01 AM
