1998 Dodge Neon Brake Lights Out
MYCAR'SMESSEDUP
Well, this probably sounds like a stupid question, but my brake lights don't work for my neon. I replaced the bulbs, and the fuses all seem to be good. Somehow I'm not gettin any power to the lights... I think. Guess I'm no mechanic, but it seems like this should be a simple problem to fix. Why does it seem like my car just has something against me? Any help would be greatly appreciated.
Dec 16, 2006 at 5:57 AM
BACKYARDMECHANIC
  • 337 POSTS
Check the brake switch located on the brake pedal. Its either defective or needs to be adjusted. Also check that all the wires are still on and haven't come off. Hope this helps. BYM :)
Mar 26, 2021 at 3:24 AM
Suggested Repair
Check the brake light switch on the brake pedal; it may be defective or need adjustment. Also confirm the switch wires are still connected.
Conversation Summary
The owner of a 1998 Dodge Neon reports that the brake lights do not work. The bulbs were replaced and the fuses appear good, but there seems to be no power at the lights. The expert recommends checking the brake switch on the brake pedal for a defect or needed adjustment and verifying that its wires remain connected.
