If car crank but no start
check fuses
you can cycle key on off three times ending with key on code will appear at /in the odometer area p ####
get the code s come back here post them for more help
you should also check for fuel and spark
check your fluids coolant and oil
if no crank check battery and fuses
SPONSORED LINKS
Tuesday, January 29th, 2008 AT 6:13 PM
