2000 Dodge Neon Oil Light on Turns
ZACPOBROMA
i have a 2000 dodge neon wiht 125,000 miles on it. it has a sohc, 4 banger. my oil light turns on when i turn a corner, then turns off as soon as i get back on the gas. is this an actual problem, or just some kind of sensor error? any info would be great! thanks
Feb 24, 2007 at 11:47 AM
CHEVY22
  • 1,375 POSTS
my first question would be is the oil full , sounds like you may be low ???? check that and let us know
jim
Feb 24, 2007 at 11:49 AM
ZACPOBROMA
that what i dont understand, the oil is full, right where it should be. this isn't a new problem though. it used to only happen when it was really cold, and the car had been sitting a while. then it became more frequent. but when i check it out it turned out to not be the cause
Feb 24, 2007 at 12:26 PM
CHEVY22
  • 1,375 POSTS
im wondering if the oil pressure switch is bad or the connector is loose , it is located on the right side of the engine block , check that out , have someone move the connector and wiring while you watch the dash and let me know
jim
Feb 24, 2007 at 12:40 PM
ZACPOBROMA
i wiggled it every which way, got nothing///
Feb 24, 2007 at 1:13 PM
CHEVY22
  • 1,375 POSTS
here is what i was thinking , you said going around corners this happens , possibly the wiring harness being stretched , but if thats not the case , i can give you the ohm spec if you have a digital ohm meter ,or you can try replacing it , i personally dont like doing that without checking first but its up to you , the switch retails for 13.50 , one other thing there could be a problem in the cluster a short to ground or a bad printed circuit board , it all depends on if you can test these items , i will help if you need it let me know
jim
Feb 24, 2007 at 2:03 PM
ZACPOBROMA
so i was driving down the freeway when the oil light came back on. it was flasing on and off randomly, as before. so i got fed up and pulled into a gas station, my car was almost pouring oil onto the ground. so i filled the oil back up and took it to the shop. at first they thought it was the head gasket, but turns out the problem was a broken sending unit.
i used this site before, and had about the same problem, asnd somebody told me that it was the sender that wasn't working properly... i should have jsut listened.
i took it to the mechanic and they had no idea, the just figured that the oil was "sloshing".
This site is awesome, keep up the good work!
thank you for all your help!
Mar 3, 2007 at 8:19 AM
CHEVY22
  • 1,375 POSTS
hi that was me and thanks fo letting us know what happened , good luck with the car
jim
Mar 3, 2007 at 8:27 AM
Suggested Repair
Confirm the oil level, then inspect the oil pressure sending unit and its connector on the right side of the engine block. Wiggle the connector and wiring while watching the dash. If the switch tests bad or the leak and warning persist, replace the sending unit; also consider a cluster short or bad printed circuit if the sender checks out.
Conversation Summary
A 2000 Dodge Neon with about 125,000 miles showed the oil light when turning corners, then it went out under throttle. The light had started only when cold and became more frequent. Oil level checked full, and wiggling the sender connector did not change the light. An expert suggested a bad oil pressure switch, stretched wiring, or a cluster circuit fault, and offered resistance specs before replacement. Later the light flashed on the freeway and the car was losing oil. A shop first suspected a head gasket, then found a broken sending unit, which the owner confirmed as the cause.
