1997 Dodge Neon Maybe injectors.. you tell me
1997 DODGE NEON
HAOLE04
Heater problem
1997 Dodge Neon Front Wheel Drive Automatic 140K+ miles
Buring 4 quarts of oil a week... Had someone glance at it... Checked the oil and it looked full BUT~~~ you could see the dipstick through the oil.. thinking maybe the injector seals are bad... You oponion would be? I am also seeing the service enging idoit light( goes out when new oil is poured in for about 10 min.)
Feb 5, 2009 at 3:07 AM
MMPRINCE4000
  • 8,548 POSTS
A bad injector seal will usually cause a gas leak and/or a vacuum leak.
The idiot light is probably a low oil warning light. You can have the error codes read at most autoparts stores for free.
The biggest problem is oil consumption, is a lot of blue smoke coming out the exhaust? Do you have any LARGE oil leaks?
Have a compression/leakdown test performed, it may be bad rings. If you drain oil into a pan and it is thin/watery and you should be able to smell gasoline.
Feb 5, 2009 at 11:58 PM
