1996 Dodge Neon fuel pessure is 52 psi
ASHLEYW8
  • 1996 DODGE NEON
  • 4 CYL
  • 12,400 MILES
This is the dodge neon that dies at moving for about 20 feet but when the brske on at 2000 rpm it keeps funning
Sunday, September 27th, 2009 AT 4:01 PM
BMRFIXIT
  • 19,053 POSTS
Check for a vacuum leaks
check for trouble codes
check and clean IAC valve
Sunday, September 27th, 2009 AT 4:09 PM
ASHLEYW8
  • 5 POSTS
I have every on the list you gave me we have sending message to each other fo the last few weeks
updated:
there is no vacuum leaks we hook hook up the snap on scaner no codes came up walk through all the program ( ok ) could it be the speed sensor located in the trans the manuel does no say any way to check it
Sunday, September 27th, 2009 AT 5:06 PM
BMRFIXIT
  • 19,053 POSTS
Using the scanner can you control the RPM
also using the scanner do a min RPM test
Tuesday, September 29th, 2009 AT 7:22 PM
