HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Dodge
Neon
Engine
Timing Belt
Replace/Remove
SPONSORED LINKS
1995 Dodge Neon Timing belt
ANTOINETTE AIONO
MEMBER
1995 DODGE NEON
Engine Mechanical problem
1995 Dodge Neon 4 cyl Front Wheel Drive Manual
Is it true that if your timing belt breaks you have to replace the engine?
Monday, May 17th, 2010 AT 5:53 PM
MECHANIC
Hi there,
Yes this is the case with your engine, your engine is what is called an interference engine and with the belt broken, pistons will strike open valves.
Mark (mhpautos)
SPONSORED LINKS
Tuesday, May 18th, 2010 AT 8:22 AM
Please
login
or
register
to post a reply.
Related Timing Belt Replace/Remove Content
1995 Dodge Neon Timing Belt Replacement
Ok, Broke A Timing Belt On Highway(@65mph) I Just Replaced Belt, When I Re Installed New One, I Got #1 Cylinder Tdc, And Put Crank And...
Asked by
cqa9
1995
DODGE NEON
Engine Mechanical Problem 1995 Dodge Neon 4 Cyl Front Wheel Drive Automatic How Do I Take Off The Timing Cover? Do I Have To Remove...
Asked by
TED MCF.
1 ANSWER
1995
DODGE NEON
How To Change A Timing Belt
Asked by
mkpjr2007
1 ANSWER
1995
DODGE NEON
Hi, I Have A Friend With A 1995 Dodge Neon. But Honestly I Dont Know How Many Mile Are On It. But Heres My Question What Do You Need To...
Asked by
capermechanic
1 ANSWER
1995
DODGE NEON
Replace Timing Belt And Water Pump?
Hello, I Recently Purchased A 1998 Dodge Neon Coupe. It Has The 2.0 Litre Dohc Motor. When I Bought It Used It Had 67,108 Miles On It, And...
Asked by
Staplesa
DODGE NEON
VIEW MORE
SPONSORED LINKS
Serpentine Belt Replacement Acura MDX
How to Replace Serpentine Belt Toyota Prius
Serpentine Belt Replacement Chevy 1500
Online car repair manuals
