1999 Dodge Magnum can it run without the ac lines being hoo
1999 DODGE MAGNUM
89,000 MILES • V8 • 4WD • AUTOMATIC
DUMMY1980
  • 5 POSTS
My wife tailended someone and i had to replace the hole front clip. The only problem is I didn't get the ac radeator so I have nothing to hook the two lines to. I dont care about the ac I just want it torun asap. can I just plug them off? the a/c compresser dose not have its own belt. The truck has a serptine belt
Mar 24, 2010 at 10:32 AM
If the AC compressor has its on own belt remove or cut it off and plug the condenser lines up-
Mar 24, 2010 at 10:36 AM
DUMMY1980
  • 5 POSTS
it has a serpentine belt that raps around everything.
Mar 24, 2010 at 11:28 AM
Get the belt w/o AC or you can leave be as you wish
Mar 24, 2010 at 12:04 PM
DUMMY1980
  • 5 POSTS
Thanks for the info. I dont realy have the money for a belt, and its my only ride. I thought that maybe I could hook the two lines together useing a peice of hose and a couple of hose clamps. That way the oil don't run out of the compresser and lock up ruining the belt. What is your thought on this idea? and once again thank you for all your help.
Mar 24, 2010 at 5:52 PM
Just make sure it doesn't leak
Mar 25, 2010 at 7:43 AM
