2007 Dodge Magnum Air Conditioner Blowing out hot air...
2007 DODGE MAGNUM
48,000 MILES • 6 CYL • 4WD • AUTOMATIC
STARZ1632002
My 2007 Dodger Magnum is blowing out hot air when I turn on the AC. It started off as all of the vents were blowing out hot air when i turned on the AC. I took it to get the air coniditioner re-charged. Since then now only the driver side blows out cold air. The passengers vents and the vents that blows into the back seat still blow out hot air. Any advice?
Jul 22, 2009 at 10:51 AM
KHLOW2008
  • 41,814 POSTS
Hi starz1632002,
Thank you for the donation.
Your problem should be the air mix doors not closing correctly allowing the heater to interfere with the AC.
Try operating the heater to maximum hot and back to AC a few times to see if the problem is rectified. If not you would have to look at the air mix door operations.
Jul 23, 2009 at 5:16 AM
