2002 Dodge Intrepid Oil Light at Idle
SCANAM
Just bought a 2002 dodge intrepid.I believe it is a 2.7 litre motor.It has 122000 kms.The oil pressure switch was replaced prior to us buying it.When you drive for a period of time on the highway the oil light comes on when you come to a stop but as soon as you step on the gas it goes out.Also the check engine light has came on and is not going out.It still works good and sounds good.Someone told me it could just be a sensor.Does anyone have any advice for me?Thanks so much for all your help in advance.
Aug 19, 2007 at 9:18 AM
SERVICE WRITER
  • 9,123 POSTS
I have some information, but you might not like it. You need to get an external oil pressure gauge that will reach up to the windshield to monitor the real pressure so you can see it when the oil pressure drops...and probably is.
Aug 19, 2007 at 1:53 PM
Suggested Repair
Use an external oil pressure gauge that can be seen from the driver's seat to confirm actual oil pressure when the oil light comes on at a stop after highway driving. The expert suspects real pressure is dropping rather than only a sensor fault.
Conversation Summary
The owner of a 2002 Dodge Intrepid, believed to have a 2.7L engine and about 122,000 km, says the oil light comes on at a stop after highway driving and goes out when accelerating. The oil pressure switch was replaced before purchase, and the check engine light is also on, though the car still runs and sounds fine. The expert advises monitoring with an external oil pressure gauge visible from the windshield, indicating the actual pressure is likely dropping.
