Oil Light Issue
NCP911
I have a 1998 Dodge Intrepid with 116,000 miles and a 3.2L engine.
My question is there a reason why my oil light would be coming on for no aparent reason? There is plenty of oil and I do not see any leaks. The engine light is not on either. It just started to do this. Please Help this is driving me baty.
Sep 5, 2007 at 8:46 AM
MERLIN2021
  • 17,250 POSTS
The light at this stage is telling you the pressure is low! Have it checked by a gauge! Might be time for a new oil pump or engine bearings! Maybe you should use a heavier oil. But first test the pressure!!!
Sep 5, 2007 at 9:04 AM
NCP911
[quote:a6083bcb31="merlin2021"]The light at this stage is telling you the pressure is low! Have it checked by a gauge! Might be time for a new oil pump or engine bearings! Maybe you should use a heavier oil. But first test the pressure!!![/quote:a6083bcb31]
It only happens when the car is warm and is at idle. If I apply gas It turns off.
Sep 5, 2007 at 9:27 AM
