My 2000 Dodge Intrepid, 2.6L Automatic Transmission, 104000 miles, while stopping after the engine has fully warmed up and has been driven for 7-10 miles, engine oil light comes on. The problem occured before and I had an oil pressure sensor replaced, the problem still there. The light only comes up when stopped and still in drive, the RPMs at this time are 500. If for some reason engine revs up slightly while stopped the light goes away. Engine has no hestitation even during starting in cold weather. What can be possibly wrong, and how much would be to fix the problem? Is it an oil pump or faulty pressure sensor?
Thanks,
Chetak
Thanks,
Chetak
Dec 8, 2006 at 12:58 AM
