1994 Dodge Intrepid Overheats
RAY001
I have a question :?: I want to know if any one could help me. This car is stressing me out and will soon leave me broke. My car runs good there is no trouble there. The problem is my car overheats. I have taken it to get the radiator clean thath's not the problem. I recently changed the water pump, thath's not the problem. The thermostat is working, thath's not the problem. And just yesterday I changed the catalytic, the catalytic on the car was good, yet when they take it off its to late to change your mind. No one will do anything for free. I have taken it to varios mechanics telling me the car overheats because of all the things that I already repaired. So all those things aren't it. One mechanic told me it might be the heads of the car. But two mechanics have assured me it could not be the heads of the car because they look new, and if it were the heads it would start leaking water in the motor oil, and thats not the problem. WHAT'S THE PROBLEM??????????????????????????HELP!!!!!!!!!!!!!![/b]
Apr 21, 2006 at 11:01 AM
LOSONE
  • 1,616 POSTS
It sounds like you have a coolant fan problem. When ti gets hot check to see if the fan is turning at a high RPM. Also when you turn on the A/C both fans should come on. let me know
Apr 21, 2006 at 11:05 AM
Suggested Repair
Check the cooling fans. When the engine is hot, confirm the fan is turning at high RPM. With the A/C on, both fans should come on.
Conversation Summary
The owner of a 1994 Dodge Intrepid with a 3.5L engine reports overheating despite a cleaned radiator, a new water pump, a working thermostat, and a replaced catalytic converter. Mechanics disagreed about the cylinder heads, and oil is not mixing with coolant. The expert suggested a cooling-fan problem and advised checking that the fan runs at high RPM when hot and that both fans come on with the A/C.
