2004 Dodge Intrepid
CHESAPEAKE
  • 2004 DODGE INTREPID
  • 6 CYL
  • FWD
  • 65,000 MILES
I am not able to fill my gas tank. The pump cuts off as if it is full but it's not. Can you help me?
Friday, June 19th, 2009 AT 1:06 PM
  • 109,885 POSTS
THis could be a couple problems. First, there is a check ball in the filler tube that is designed to prevent fuel from leaking from the tank in the event of a roll over. If it is stuck, fuel will only go into the tank very slowly. Also, when you look into the filler tube, you will notice there a large tube for the fuel to enter the tank, and a smaller one as a vent. It could be plugged and not allowing air to exit the tank.
Monday, June 22nd, 2009 AT 10:32 PM
