1997 Dodge Intrepid Car smoking and a gas smell
DODGEDUDE2666
  • 5 POSTS
Engine Performance problem
1997 Dodge Intrepid 6 cyl Front Wheel Drive Automatic
I have a 97 dodge intrepid. Around last december we had to park the car up until now. Today I cranked it up 3 different times and everytime within a couple minutes of running the car is smoking really bad from the tail pipe and there is strong smell of gas. What could this be? What could I try? Thanks for any and all help.
Oct 20, 2010 at 10:21 AM
  • 110,244 POSTS
What color is the smoke, white, blue, black... Also, where is the fuel smell coming from?
Oct 20, 2010 at 3:38 PM
DODGEDUDE2666
  • 5 POSTS
The smoke is white and the smell is just in general when the car is running. Also when you pop the hood you can smell it stronger there to
Oct 20, 2010 at 4:33 PM
  • 110,244 POSTS
White smoke usually indicates there is coolant getting into the combustion chamber via a bad head gasket. Does the smoke stop if you let it run? Is it low on coolant? As far as the fuel smell, check around the fuel rail, injectors, regulator...
Let me know what you find.
Oct 20, 2010 at 4:36 PM
DODGEDUDE2666
  • 5 POSTS
Ok I will and when I first cranked it up the and I cut the car off it didn`t want to crank back up like if it was flooded
Oct 21, 2010 at 3:39 AM
  • 110,244 POSTS
Something tells me there is a head gasket issue. It isn't a common problem on these vehicles. Let me know what you find.
Oct 21, 2010 at 4:11 AM
DODGEDUDE2666
  • 5 POSTS
Is there anyway I can check to make sure it is the head gasket?
Oct 21, 2010 at 4:13 AM
  • 110,244 POSTS
Watch if there is coolant consumption, check engine compression... If the white smoke is there even after the engine is warmed up, that is my guess.
Oct 21, 2010 at 4:25 AM
