2003 Dodge Intrepid cam timing senor
DUPRIE11
Computer problem
2003 Dodge Intrepid 6 cyl Two Wheel Drive Automatic
Can you show me where the cam timing senor is on a 2003 Dodge Intrepid. And if it is easy enough to replace myself.
Jan 10, 2010 at 11:55 PM
CH112063
  • 1,320 POSTS
I'm not sure if your engine is a 3.3L or a 3.5L its best to get the correct part first, then ask one of the techs here for help, you'll need to have the tools, it's usually a 10mm head screw, get your parts and tools, then ask the techs, because if you haven't done one before you may get into more trouble than before. I don't think it's too difficult if you take your time and work slowly, ok?
Jan 11, 2010 at 1:30 PM
