2002 Dodge Intrepid
SLIMMER455
  • 2002 DODGE INTREPID
Shakes or Wobbles problem
2002 Dodge Intrepid 6 cyl Front Wheel Drive Automatic
hey guys got a bad vibration between 55 70 mph. Tires are newer about 20000 mi. On them. Had them balanced and checked twice still have the problem. It looks like the front tires are a little more worn on the outer edge. The steering wheel does not shake when it is vibrating/wobble. Could it be something in the front end bearing, alignment, tie rod etc.I don not hear any grinding noises. Any help would be appreciated thanks Mike
Saturday, May 16th, 2009 AT 10:54 AM
JDL
  • 16,098 POSTS
Go around the vehicle, jack-up the tires, shake-em and pull-em, see if you feel anything. You might also check the struts/shocks.
Rotating the tires doesn't change anything?
Saturday, May 16th, 2009 AT 12:12 PM
