1995 Dodge Intrepid rack steering
ZEB656
  • 5 POSTS
Steering problem
1995 Dodge Intrepid 6 cyl Front Wheel Drive Automatic
streering wheel moves buy tires don't fluids are full ????
Jul 30, 2010 at 2:12 AM
  • 110,248 POSTS
How far can you turn the steering wheel before the tires begin to turn?
Jul 30, 2010 at 4:36 PM
ZEB656
  • 5 POSTS
the tires don't move at all you can turn the steering wheel alot but it wiil stop tires don't move
Jul 30, 2010 at 10:21 PM
  • 110,248 POSTS
Then either a steering component (tie rods) or the rack has come disconnected from the steering column (very odd). Have you checked those things? The only other thing is if the rack has come apart internally. Again, that is very odd.
Jul 31, 2010 at 1:14 PM
ZEB656
  • 5 POSTS
i think the last thing you said is what is wrong ;rack has come apart internally , what should i do ???
Aug 1, 2010 at 3:32 PM
  • 110,248 POSTS
If the you can see the steering shaft turning the rack but nothing is happening, the only thing you can do is replace the rack and pinion.
I wish I had better news.
Aug 1, 2010 at 5:14 PM
ZEB656
  • 5 POSTS
Thank you , Joe, I thought so , but hoped not . And now you know this can happen without warning , luck for me it happaned as I was parking . Thank you , zeb656 , I'm woman & can do... Thanks.
Aug 2, 2010 at 3:03 AM
  • 110,248 POSTS
If you decide to do it yourself, let me know if you have questions.
Aug 2, 2010 at 5:30 PM
ZEB656
  • 5 POSTS
It turned out to be just two bolts that hold the tie rod ends in place that broke at the rack.... Thank you so much for your help... zeb656
Aug 20, 2010 at 12:35 AM
  • 110,248 POSTS
Glad you got it fixed. Let us know if you have questions in the future.
Aug 20, 2010 at 2:35 PM
