My engine light came on and I had the dealer check for codes. I don't know the alpha-numeric code, but this is what the tech said it was. He took the sensor out and found it full of oil. He said I needed a new one ($187) but I cleaned that one and reinstalled it and it works fine...for about 24 hours. Then I have to repeat, etc.
This car has the 2.7 litre engine in it, which I am learning has been a problem issue with Chrysler for some time. I run synthetic oil in the engine. The tech says that the engine is just blowing oil and that only real fix is a new engine. Is there any thing I can do to control the oil flow/blowing problem? Would a heavier weight oil help? The car looks almost new, but due to age, I'm not sure I want to buy an new engine for it.
Jul 27, 2010 at 12:59 PM
