2000 Dodge Intrepid needing opinoins
SWEET_BESO69
Shakes or Wobbles problem
2000 Dodge Intrepid 6 cyl Front Wheel Drive Automatic
every time i turn on my air and leave it running my car starts shaking,engine light comes on and it will stall. If i turn off air and car for awhile then turn it back on everything is back to normal....what is going on?
Feb 8, 2009 at 8:13 AM
  • 110,251 POSTS
Does the engine run normally with the ac off? Also, do you have the same problem with the defroster on?
Feb 14, 2009 at 7:03 AM
SWEET_BESO69
yes it runs normal w/o ac on and when the defrost is on it too also runs normal.
Mar 6, 2009 at 1:31 PM
  • 110,251 POSTS
Hi:
I need you to check for vacuum leaks in the engine compartment and under the dash.
Let me know what you find.
Mar 6, 2009 at 1:33 PM
