2000 Dodge Intrepid Engine light on and failed smog test
139,450 MILES • 6 CYL • FWD • AUTOMATIC
MUSTANGFAN006
Hi
My car's engine light is on and when a reader is used to determine the problem it states that the problem maybe the catalytic converter or the oxygen intake valves.
After talking with a mechanic who listed the usual noises of a bad catalytic converted i don't think that it is the problem.
I think a leak in the vacuum system is the problem.
How can i make sure it is a leakage in the vacuum system and not the catalytic converter?
And how can i get it fixed?
Jan 20, 2009 at 10:46 AM
MASTERTECHTIM
  • 4,750 POSTS
you will need the use of a scan tool that a repair staion has because you will need to watch the sensors when its running to determine if its a vacuum leak, o2 sensor or faulty converter. unfortunately there is no fast fix
Jan 20, 2009 at 10:54 AM
