If the battery has a full charge, check the battery cables/wires. If that checks ok, just pick one circuit that doesn't work, check that circuit. If the starter won't even crank, start there. There is a starter relay in the power distribution center under the hood. Unplug the relay, use a testlite, the switch side of relay should be hot all the time, the voltage for the coil side of relay goes hot with the key in the crank position.
Have you tried cranking in neutral?
SPONSORED LINKS
Thursday, July 16th, 2009 AT 11:18 AM
