1999 Dodge Intrepid Speed Sensors
ROLUV23
Transmission problem
1999 Dodge Intrepid 6 cyl Front Wheel Drive Automatic
How do I change the Input/Output Speed Sensors in my car
Jan 10, 2010 at 6:27 AM
ERNEST CLARK
  • 1,730 POSTS
Glad to help.
Well, there's no such thing as an "Input/Output speed sensor". All "Sensors" are inputs. "Outputs" are always solenoids/relays or display devices/lights.
You have only one "Vehicle Speed Sensor" and that's located on your transmission. And changing that is as simple as disconnecting the wires and unscrewing the sensor.
You also have "Crankshaft" and "Camshaft" speed sensors. These are a bit more complicated to remove/replace.
Why do you need to replace any of your sensors???
And always make sure the actual sensor is faulty by testing it before you replace it.
Jan 23, 2010 at 1:24 AM
