1999 Dodge Intrepid alternator
GREGTHOS
  • 1999 DODGE INTREPID
Electrical problem
1999 Dodge Intrepid 6 cyl Two Wheel Drive Automatic
How do I replace an alternator on a 1999 Dodge Intrepid?
Saturday, October 25th, 2008 AT 9:53 PM
  • 109,709 POSTS
Hi:
I recommend that you purchase a manual that provides stsp by step instructions, and provides pictures to identify parts. If you can't get one, I hope this helps. Keep in mind, I'm not there to see everything you see, so I will give you a general procedure to follow.
1) Disconnect battery
2) Remove the alt drive belt
3) Remove (3?) Bolts holding alt
4) Remove alt
Reverse the order to replace the new one.
I hope this helps.
Tuesday, November 4th, 2008 AT 1:38 PM
