2000 Dodge Intrepid just replaced alt. batt diffcu start ca
2000 DODGE INTREPID
202,270 MILES • 6 CYL • FWD • AUTOMATIC
CORONA89
i just wanted 2nd opinion! i have whats called a "maintenance free" battery it is difficult to get to u have 2 remove the wheel..i have never had aproblem w/ batt i could leave radio on for hrs get in and she start right up best luck ive ever had w/ a batt! anyhoo let me take you where it all started! batt light comes on so we take clean,batt new batt ends! so it didnt fix my problem then i knew it was the alternator it never went completely out cuz the car was running but wouldnt shift out of low saftey reason i suppose1 well put alt on everything was fine ran better than everi didnt have problem with batt til 2-3dy later! it doesnt matter how far i drive it leave it sitting for 30 min it gives u hard time to start! it will make clicking noise rapidly but if i turn key off then back 2 the on position wait 5sec rep..5xto start it
Apr 26, 2010 at 2:13 AM
Load test the battery if okay make sure the connections are cleaned and tight-if it continues start checking the starter, starter relay, transmission range switch and ignition switch.
Apr 26, 2010 at 8:46 AM
