1998 Dodge Intrepid Stalling
NICARERO
  • 1998 DODGE INTREPID
  • 6 CYL
  • FWD
  • 108,000 MILES
In the winter, my car will stall out when I take it out park, if anyone knows what could be causing this it would be greatly appreciated.
Tuesday, January 27th, 2009 AT 5:44 PM
  • 109,885 POSTS
Hi:
Does this only happen in cold weather? Is the check engine light on? Have you had you fuel pressure tested in the cold temps?
Friday, January 30th, 2009 AT 5:03 PM
NICARERO
  • 7 POSTS
Yes it is only in the cold weather, the check engine light is not on, and I have not had the fuel pressure checked.
Saturday, January 31st, 2009 AT 12:51 PM
  • 109,885 POSTS
Hi:
If the light isn't on, I would start by checking fuel pressure in the cold conditions. The pump could be getting older and not like the temps. You could do this yourself. Most nationally recognized parts stores will lend or rent the gauge and it hooks to the fuel rail.
Let me know what you find.
Saturday, January 31st, 2009 AT 2:20 PM
NICARERO
  • 7 POSTS
You wouldnt happen to know the location of the port I cant seem to find it
Monday, February 2nd, 2009 AT 6:21 PM
  • 109,885 POSTS
Hi:
Exact location, no, but it should be on the fuel rail. I believe there will be a cap on it.
What exact engine do you have and I'll see what I can dig up for you.
Monday, February 2nd, 2009 AT 6:51 PM
NICARERO
  • 7 POSTS
I have the 2.7 v6 engine.
Monday, February 2nd, 2009 AT 8:18 PM
  • 109,885 POSTS
Hi:
I looked several places and can't find a picture for you. However, there is a site here that may help you identify what you need and it explains how to check pressure. Go to:
https://www.2carpros.com/dia/test_fuel_pressure.htm
Let me know if this helps you.
Monday, February 2nd, 2009 AT 8:58 PM
NICARERO
  • 7 POSTS
Thanks wont be able to do it til friday so ill let you know
Tuesday, February 3rd, 2009 AT 11:55 AM
Related Engine Stall While Driving Content
